When I disassembled my firewall and removed the vent stovepipes I noticed a sealant similar to roofing tar around the edges of the flange. When I heated the bonding adhesive you could see this "tar" bubble...which the bonding adhesive does not do.When I look at the AIM, it calls for the flange to bond with a bonding connection "B" (90 degree butt joint)...but there is no mention of any further glue or sealant. The aim does show an adhesive but it looks to be the adhesive that glues the foam seal to the front edge of the stovepipe that fits to the back of the filler panel on the firewall corners.If there was tar sealer put on, how was it done and why doesn't the AIM reference it?I have my stovepipes bonded back in and I want to determine if I am done before final assembly or do I have sealer to administer...Thanks
edit, 1965 car
edit, 1965 car
