1969 front brake backing plate"gasket"? - NCRS Discussion Boards
  • Joe T.
    • October 25, 2006
    • 304
    I pulled the front rotors and backing plates off and noticed some kind of gasket like material around the spindle behind the backing plate, but only on one side. I don't see this in the assembly guide or the service or overhaul manuals. Shall I replace the missing material with the self-made gasket stuff? Thanks...Joe
    • 43248
    Re: 1969 front brake backing plate"gasket"?
    Joe-----
    Yes, a gasket was originally used. It was GM #3953431. It's discontinued but I believe reproductions are available from sources like Dr. Rebuild. You could also make a satisfactory gasket from gasket stock.
    • Joe T.
      • October 25, 2006
      • 304
      Hi Joe!!! and thanks, as always deepest regards,,,joe
