Just bought the correct '62 cigarette lighter but after reading some older posts about no factory fuse protection, think I should add an inline 20 amp fuse or as Jack Humphrey has suggested, the add on protection to socket itself made by Casco. Where is best place and how to add the fuse to wire to lighter to give best protection from the mentioned possible fraying of insulation on wire from wiper cables? Do I remove the lighter socket to get to wire or add closer to ammeter? If I go with Jack's suggestion, where does this add on go on socket? Have to remove socket? Goes on back or inside of socket? Couldn't really tell from description in older posts? While I'm at it , where would I put a fuse(1 amp adequate?) for wire to clock?
Thanks in advance
Thanks in advance
