1969 L36 Alternator 1100833 Pulley/Fan - NCRS Discussion Boards
  • Steve C.
    • December 26, 2012
    • 3
    I am trying to find the subject alternator which is hard enough but I also want to make sure I get the right pulley and fan. My car has no P/S and no A/C, so I think I need a 3829387 (Broadcast Code "AI") pulley. Am I on the right track? Also, are the stamped fans common to the different 10SI variants or different? How do I identify the one that is required for the 1100833 for no P/S and no A/C? Guidance appreciated.
    • 43221
    Re: 1969 L36 Alternator 1100833 Pulley/Fan
    Steve------
    Pulley was GM #3846180. Fan was GM #3843346. However, late 1969 may have used fan GM #1966990. Part numbers are NOT stamped anywhere on the fans. I do not recall if the 3846180 pulley was stamped with a part number.
    • David L.
      • July 31, 1980
      • 3310
      You can find a drawing of the 3846180 pulley in the link below (Mar. 12, 2011 @ 6:58 PM).
      Enclosed a photo of a NOS 3843346 fan as well as 2 photos of a used original (front & back).
      Dave
      https://www.forums.ncrs.org/showthre...971#post542971
      • David L.
        • July 31, 1980
        • 3310
        Apparently there were two versions of the 1966990 fan (photo below), different manufacturers I assume. The one on the right side has a "shark tooth".
