58 positraction rear end date e/8 - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    Looking at a 3.36 rear end with housing casting number 3743838 and casting c-30743 and a date E/8. I never seen a date code with a slash. Could this actually be May 1st 58? Did 58 vettes come with a 3.36 gear?
  • Larry C.
    • March 31, 1980
    • 279
    Re: 58 positraction rear end date e/8
    Brandon,
    According to the NCRS Pocket Spec Guide, 1957 -1958 Corvettes were available with a 3.36 axle ratio with the Code AE and was standard with powerglide; however, that ratio is "suspect" as above for 1955- 1956, the AE code was for a 3.55 ratio.
    Some years ago, I owned a 1956 with powerglide and a 3.55 ratio axle and the carrier was stamped "AE". Further, the 1959 - 1960 Corvettes are listed with a 3.55 ratio and code AE.
    The 3.36 ratio axle does not show up until 1961 with a code of AC.
    Larry
    • Brandon T.
      • October 23, 2008
      • 872
      Originally posted by Larry Chilton (3506)
      Brandon,
      Larry
      Thanks for the feedback Larry. The date is what is confusing to me. E/8.
