Alternator I.D. - NCRS Discussion Boards
Alternator I.D.
  • Stuart F.
    • August 31, 1996
    • 4676
    Alternator I.D.
    Further to my recent thread about my battery problems, I've begun an effort to re-establish what I did back in the early 90's with my alternator(s) as it now affects my battery charging problem;
    The alternator I now have on the car and it is now suspect as the cause of my problem is a:
    1100628-37A
    361-12v NEG
    I now blieve this to be a replacement 1969 unit I got from "Chicago Corvette" (sorry, but I lived within 15 minutes of their place back then).
    I have another unit that looks to be my original that I apparently never restored. It is a;
    110063 (rest filed off)
    9J10 12v NEG
    Now then, being away from my reference books, can any one ID these two units???
    I have the correct SHP pully and fan (loose) to go on a third alternator that was a new unit I bought from Sears back then. My intention is to put this one on my engine and then restore one (or both)of the above units. I also have another new (correct) Voltage regulator, but I'm considering trying to get a new solid state unit to go with my new Sears alternator in order to get back on the road.
    Thanks for any help you can offer.
    Stu Fox
    • 43243
    Re: Alternator I.D.
    1100628-37A
    361-12v NEG
    9J10 12v NEG
    Stu Fox
    Stu------
    The 1100628 was used for some 1963-64 Corvettes as well as other applications. It was the base 37 amp unit, just as yours is marked. The date code doesn't look right so I can't say when it was manufactured.
    There was no alternator of GM #110063. If you mean GM #1100633, that is a 55 amp unit used for 1963 Corvettes. This one was manufactured on October 10, 1969 so it was originally a SERVICE alternator.
    • Stuart F.
      • August 31, 1996
      • 4676
      Re: Alternator I.D.
      Joe;
      Thanks for the quick response. On closer inspection, I believe the date code to be "3G1" on the 1100628 on the car, and therefore probably my original. Thanks for straightening this out for me. The other one I have then (the 110633) is the 69 replacement. Odd that it looks to be in scruffier condition than my original. Perhaps it was a used one.
      Regardless, the 1100628 unit on the car failed the diode test while the 110633 passed.
      Thanks again Joe. Have a great weekend.
      Stu Fox
