coil bracket question - NCRS Discussion Boards
  • Kevin M.
    • September 19, 2013
    • 72
    Does the 1958 230hp use the same coil bracket as the 63-67 ?
  • Mike E.
    • February 28, 1975
    • 5141
    Re: coil bracket question
    I'm pretty sure they are not. As I recall, the tab with the threaded hole for shielding retention is toward the firewall on the 57-62, while the 63-67 is toward the front of the car.
    • Kevin M.
      • 72
      Thank you Mike
        • 43258
        Kevin------
        Sort of. The 1958 bracket was GM #3751338. That bracket was discontinued in July, 1963 and replaced by GM #3826072. The latter was the 63-67 small block bracket.
