Coil Bracket from ?? - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Your Help please. Identifying this bracket.
    Thank YOU.
    Ray
    I hope you dance
  • Patrick B.
    • August 31, 1985
    • 2003
    Re: Coil Bracket from ??
    The cut lower corner of the near tang shown in the side photo is necessary for clearance with a 67 427 3 carb manifold. I don't know if any other engine required this configuration.
    • Ray G.
      • May 31, 1986
      • 1189
      Thank you Patrick;
      Does the bulge around the resistor screw mounting look familiar ?
      I hope you dance
      • David L.
        • July 31, 1980
        • 3310
        My 1967 Chev. Parts Catalog (Apr. 1967) lists GM 1943712 as the part # for the 1st design ignition coil mounting bracket and GM 1968423 as the 2nd design bracket for the 67 Corvette (427) in Gr. 2.183.
        Dave
        • Ray G.
          • May 31, 1986
          • 1189
          Thank YOU Pat & Dave.
          I hope you dance
            • 43247
            Originally posted by Ray Geiger (9992)
            [ATTACH=CONFIG]52092[/ATTACH][ATTACH=CONFIG]52093[/ATTACH]
            Thank YOU.
            Ray
            Ray-------
            I wonder if the "bulge" at the resistor tab was always there. Notice how the "bulge" above the tab is greater than that below. I don't see how or why it could have been manufactured this way. Also note that the bracket appears somewhat distorted on the left side.
            If it was created the way it appears now, then I don't think it was used for a Corvette application and perhaps not even a Chevrolet application.
            • Ray G.
              • May 31, 1986
              • 1189
              Good point Joe.
              Thank YOU.
              I hope you dance
              • David L.
                • July 31, 1980
                • 3310
                Ray,
                I did some research on Chevrolet ignition coil brackets several years ago using all my many vintage Chevrolet parts catalogs (Gr. 2.183). There were many variations of these brackets. I have collected about 12-15 of these brackets but have yet to find the box of them in my garage. I know that I do not have one like yours with the "bulge" but it might be one of the ones listed in the two pages below. I know that it is not a 1943712, 1966876, 1970344, or 1971011 bracket based on my research.
                Dave
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Thank YOU Dave.
                  I think Joe has a good point. There may have been some "bubba" involvement with "in the field" redesign.
                  I hope you dance
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Hello;
                    I was just contacted by a friend, off this site, stating he has seen this anomaly before.
                    Confused here.
                    I hope you dance
                      • 43247
                      Hello;
                      Confused here.
                      Ray------
                      It could be that this configuration results when someone tries to "reconfigure" a coil bracket to fit a coil with a smaller OD than the bracket was originally designed for. I suppose it's also possible that it was a bracket configuration actually designed for a coil with a smaller OD but I don't know of any GM coils that were smaller and, if there were, I don't think GM would have designed a bracket like this one for such a coil. Plus, as I mentioned previously, I really don't think it would have had the different "bulges" top and bottom as seen in this bracket
