Exhaust system question -c 2 - NCRS Discussion Boards
  • Larry S.
    • September 19, 2007
    • 204
    My 66 427-450 is getting a new complete exhaust system and I am not sure of the correct exhaust clamp positioning on the pipes. Should the front clamps (at the exhaust pipe to extension pipe) be positioned with the nuts up or down (vertically), or facing the inside or outside (horizontally)? Also positioning at the chrome extensions behind the mufflers?
  • Joseph T.
    • February 28, 1986
    • 169
    Re: Exhaust system question -c 2
    Larry
    Front Clamps the nuts are facing down and don't forget the 2 ground straps for radio cars.
    Rear clamps on chrome extensions- the nuts face inward on both sides
    Good luck
    • Larry S.
      • 204
      Thanks for that good information. I want to do it right the first time. (can barely wait for Spring up here in Ontario!).
      • Leif A.
        • August 31, 1997
        • 3600
        Originally posted by Joseph Tansey (9727)
        Larry Front Clamps the nuts are facing down and don't forget the 2 ground straps for radio cars.Rear clamps on chrome extensions- the nuts face inward on both sidesGood luck
        As an aside, Joseph, do side pipe cars have exhaust ground straps, as well? The ground strap kit from Paragon shows only 4 total straps.
        Leif
        • Stephen L.
          • May 31, 1984
          • 3148
          No ground straps on sidepipe cars.
          • Leif A.
            • August 31, 1997
            • 3600
            thanks...that's what I thought.
            Leif
