1969 Corvette Headlights will not go up - NCRS Discussion Boards
  • David S.
    • August 9, 2009
    • 595
    Hi All,
    69 Corvette headlight buckets will not pop up. What quick checks and diagnostics should I be looking into? Not well versed in vacuum systems.
    Dave
    • 15646
    Re: 1969 Corvette Headlights will not go up
    Originally posted by David Schutzbank (50698)
    Hi All,
    Dave
    There are oh so many possibilities and resources. By Googling '1969 Corvette headlight vacuum' I got the following:
    Search the world's information, including webpages, images, videos and more. Google has many special features to help you find exactly what you're looking for.
    I would start with :
    With the Internet the world and beyond is at your fingertips. It is a wonderful age we live in.
    • Jim T.
      • March 1, 1993
      • 5351
      David to raise your headlights to drive when they will not raise with the headlight switch or the pull down switch you can reach into the center grille and push them up by hand. They will lock in the up position. To lower them you will have to release them at the headlights "elbow" by pushing down at the "elbow". Before you start your 69 after manually raising the headlights pull down the headlight pull down switch to keep engine created vacuum from closing the headlights. On my 68 and 70 this is easy to do.
      • David S.
        • August 9, 2009
        • 595
        Hi Guys,
        Thanks for the insights. The lights are fixed. It was a loose connection at the headlight switch which was causing a vacuum leak. All fixed now.
        Dave
