1964 coupe factory AC. Serial number for the tag on the AC evap housing/box? - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Since i do not have the original tag that was placed on the outer AC evaporator box on my factory AC 1964 coupe how do i find the serial number for the AC evaporator tag?
    I suppose it will be impossible to have the correct number but i would like to have the number as close to correct as possible
    I have a serial number that is placed on the evaporator housing for a 1963 but that serial number will not be correct
    The production date for my car is December 6, 1963
    1964 Corvette Harrison Air Conditioner evaporator box metal emblem i need the "almost" correct serial number for
  • Dino L.
    • February 1, 1996
    • 694
    Re: 1964 coupe factory AC. Serial number for the tag on the AC evap housing/box?
    Best pictures I have...probably don't do you much good, this is a October 63 built 641 079.jpg1 081.jpg1 089.jpg
    Dino Lanno
    • Claus S.
      • December 30, 2010
      • 414
      Thanks Dino
      The picture is a bit small so it is not easy to see what the numbers are on the tag
      Can you tell me what the numbers on the tag on the AC evaporator housing is on the outer AC evaporator housing you have?
      What are the numers on the left side and on the right hand side
      • Harry S.
        • Harry S.
          • Claus S.
            • Claus S.
              • Harry S.
                • Harry S.
                  • Claus S.
                    • Harry S.
                      • Claus S.
