I had to "fix" a body mount situation for my 1970. Essentially the body was sitting too low due to incorrect installation by previous work done. The body now has the correct aluminum mounts and is sitting at the correct height. The result has caused the steering column to come up "short" of the rag joint assembly. See pic.
First question, this is too far off, correct?
2nd question: Correct me if i am wrong, but i need to slide the steering column into the engine compartment to make up this length? If so, what's the trick in getting the column to move? I have the plate on the engine side of the firewall removed and the two bolts under the steering column loosened but it won't budge. Thanks.
