Driveshaft Repair or Replace? - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I have a C1 driveshaft that is bent and I was going to have the tube replaced. The cost to replace is about $150 and that is about the cost of a replacement. The original has Spicer on the ends and I don't know about the replacement, but I doubt if that can be seen installed with the U-joint. Anyone have previous experience with this?
    Bob
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Driveshaft Repair or Replace?
    Bob,
    Repops are available with correct u joints all installed. The only thing I see different is the caps on the joints are not flat as the originals were. Shaft with yoke and all can be installed.
