Warning Chimes on 1995 Corvette - NCRS Discussion Boards
  • Maureen S.
    Infrequent User
    • February 14, 2014
    • 4
    My chimes on my 1995 corvette do not seem to be working. The seat belt does not chime at all. The chime for the headlights and key in ignition chime sometimes and sometimes not.
    Does anyone know how to test this? Where do I go for info?
  • Ed H.
    • November 1, 1999
    • 626
    Re: Warming Chimes on 1995 Corvette
    Maureen, what part of the country do you live in. If that was known, some local folks might be able to diagnose and offer someone local who can help. Good luck and welcome to the club.
    • Maureen S.
      Infrequent User
      • February 14, 2014
      • 4
      Located in Tucson, AZ
        • 15610
        Sounds like Tom Barr land. On the bar at the top of this page = click on the contacts button. Tom is the National Team Leader for 1990 to 1996. You will find his contact information there. Give him a shout.
        • Bill H.
          • August 8, 2011
          • 439
          First, is there a gap between the switch bezel and the steering column?
          Try this: Put the key in and push the switch towards the steering column while turning the key to "on" (not to "start"). Do the chimes come on?
          If they do, you'll probably need to replace the ignition switch. I've seen this in more than 1 C4, my 92's been this way for 8 years (it doesn't bother me enough to fix it).
          • Ed H.
            • November 1, 1999
            • 626
            Bill, sounds she is steering (NPI) for Ops or even better PV.
            • Arland D.
              Moderator
              • July 31, 1980
              • 426
              Maureen,
              Make sure to test the chime that should sound after driving one mile with one of the blinkers on............. it's fairly subtle.
