power antenna - NCRS Discussion Boards
power antenna
  • Harry G.
    • September 23, 2010
    • 13
    power antenna
    I would like to replace the power antenna on my 1981 corvette. Is there anything special about the removal and replacement I should know before I start?
    Where is the power antenna relay located
  • Edward J.
    • September 15, 2008
    • 6960
    Re: power antenna
    Harry, you'll have to lower the muffler hanger on the side the antenna is on to remove,and if the antenna mast is stuck in the up position you'll need to cut it off. as far as the relay for antenna relay I am not sure but believe its attached under the rear window trim or behind the console pass side seat under carpet.
    • Harry G.
      • 13
      Re: power antenna
      Thanks, I'll check it out this week.
