Re: Nitrogen...
Edward-
What you say is true except that nitrogen makes no difference- it leaks out at exactly the same rate as air in any given tire. The TPM systems that are very common on today's cars don't indicate a problem with air leakage, they demonstrate how often we have historically forgotten to check pressures. It's simply highlighting an underlying problem.
Edward-
As Duke and others have pointed out, the reasons why nitrogen is used have nothing to do with expansion coefficient. Although nitrogen has the side benefit of not supporting combustion, the principal reason (also pointed out above) is the 'dryness' of nitrogen vs. typical compressed air plus the portability of nitrogen bottles.
