'72 POA valve installation - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I just sent my POA valve out to Classic auto air to be rebuilt. When I removed it the evaporator housing was out of the car so room wasn't an issue. In preparing to re-install the valve with the housing in the car I see that there is no room for a 1 1/16" wrench to tighten the upper nut and I'm sure it's the same issue for the lower one. Any one have any hints or tool suggestions for this task? Thanks!!
  • Larry M.
    • January 1, 1992
    • 2703
    Re: '72 POA valve installation
    Custom made wrench………………..no kidding.
    The good news is that these connections have o-ring sealing, so the torque is very low on the nut. Make sure the threads and o-rings are lubed up good with refrigerant oil. Hand tighten, and then use your custom wrench to snug them up to spec. I think it's around 20 ft-lb.
    Larry
    EDIT: If you think you may have to remove in a few years for some reason, you might add a bit of anti-seize ON THE CONNECTION THREADS. The POA valve connections seem to gall up over time, and make removal difficult when everything else is in place.
    • Jim T.
      • March 1, 1993
      • 5351
      Did you clean the screen or replace the screen in the expansion valve?
      • Tom L.
        • October 17, 2006
        • 1439
        Hmmm, the screen is missing. The evaporator has been open for years. All the tubing and hoses are as well. Guess the screen fell out. Where can I get one??
        • Larry M.
          • January 1, 1992
          • 2703
          AC Delco #15-512, GM #5914631, NAPA #TEM 207342.
          Both GM, NAPA, and any place that handles AD DELCO parts should be able to get. About $5. I would buy 2.
          Larry
          • Tom L.
            • October 17, 2006
            • 1439
            Thanks for the info. Going back to the custom wrench for the POA valve, which was my forst thought. Has anyone has success with a crows foor socket? A friend suggested that.
            • Bill C.
              • July 15, 2007
              • 904
              Tom,
              If you take the egg crate grill out, you can get at the lower nut. I used a small pair of vise grips with tape wrapped around each half to not scratch the plating on the POA valve nut (it is gold irradiate if I remember correctly)
              the upper one is lots easier with the expansion tank removed.
              bill
              • Monte M.
                • January 1, 1991
                • 687
                Tom,
                I bought a cheap wrench and cut it in half.
                Did the trick just fine as these do not need much torque on them.
                Monte
                • Tom L.
                  • October 17, 2006
                  • 1439
                  Bill, thanks for the tip on removing the egg crate, didn't think of that
                  Monte, "Making" a tool as you describe was always my forst thought.
                  Anything else?? Thanks!!!
                  • Tom L.
                    • October 17, 2006
                    • 1439
                    I've been searching for the TXV screen and have used all of the part numbers at several auto parts stores as well as the internet but the numbers Larry provided don't seem to be valid anymore. Anyone know where I can get one?? Even a link to a vendor would be great. Thanks!!
                      • 11698
                      I find it here:
                      http://www.amazon.com/ACDelco-15-512.../dp/B000C9C7X2
                      Here:
                      http://www.amazon.com/Four-Seasons-3.../dp/B001B6XNBK
                      Here:
                      Here:
                      and here:
                      http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
                      as well as many other places.
                      You have to get working on your Google-foo, Tom.
                      • Larry M.
                        • January 1, 1992
                        • 2703
                        Currently 3 different listings on Ebay, also a few gm parts outlets on the internet still show in stock. http://www.gmpartsgiant.com/parts/gm...n-5914631.html Also http://www.gmpartseast.com/parts/gm-5914631_screen.html Prices vary from about $3 to $20 for the same/similar item….so shop for the best price w/shipping. If all else fails, let me know and I will put one in the mail. I think I still have a few extras someplace in the garage
                        Larry
                        EDIT: Not all of the links provided by Pat are correct for the AC 15-512 or GM 5914631 item that you need. The Ebay ones are fine, and you can see the pictures. It appears NAPA no longer carries the correct TEM 207342 for your/our application. The ones I have were purchased from NAPA about 5-6 years ago are are the correct shape and size for our Corvettes.
                          • 11698
                          Larry,
                          Some of the links are cross-referenced from the AC-Delco catalog:
                          Welcome to GM Parts - your new, consolidated home for GM Genuine Parts and ACDelco parts information and resources. Shop our online catalog of parts today.
                          • Larry M.
                            • January 1, 1992
                            • 2703
                            Larry,
                            http://www.acdelco.com/pdf/appcat_bu..._reference.pdf
                            Pat:
                            The two issues I saw in your list were the Four Seasons screen and the NAPA screen. The Four Seasons screen may be okay, but the picture is not correct. I see that it cross references the AC 15-512…..so the part may work, but it will not be as pictured. The NAPA screen indicates a different part number than the one I listed and previously used to purchase. The picture is also not correct……….although that again may not mean anything. However, with a different part number, I would advise Tom to be careful before buying from NAPA. NAPA indicates the TEM 207342 number I listed is no longer available.
                            The correct screen is shown in your Ebay links/references. It has a small rubber seal on the open end, and has a small taper to the screen.
                            I think together we provided Tom more than a few sources for the elusive TXV expansion valve screen. But the handwriting is on the wall…………these parts are going out of stock/production quickly. A few years ago, just about everyone had a box full. Now, one has to search for it.
                            Larry
                            • Tom L.
                              • October 17, 2006
                              • 1439
                              You guys are a huge help but it hasn't gotten easier. I stopped by Napa again and the second number is good. The catch is that you have to buy a box of 10. I'll keep looking, thanks!!
