1962 Signal Blinker Issue - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
    After getting my car back I have discovered that the signals work without turning the key on. As far as I know they should not do that. Anyone have any thoughts on what might be causing this?
  • Mike E.
    • February 28, 1975
    • 5153
    Re: 1962 Signal Blinker Issue
    Check the wires around the outer edge of the ignition switch. There are 3 terminals and 2 wires. Yours are not oriented correctly. Regards, Mike
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11366
      Yup.......
      You probably put one of the 2 Pink wires onto the Ign switch BAT terminal. I've done it before too. One Pink goes to the gauges(Fuel & Temp), other to the directional flasher circuit. One to Ign, other to Acc terminals(even though Ign and Acc is internally tied in the switch), so doesn't really matter which is which.
      I did that on the fuel and temp gauges Pink feed wire once. Were powered with key off. ooops.
      • David H.
        • November 11, 2009
        • 777
        You guys are amazing!This would have taken me forever to figure out, if I ever did figure it out!You were absolutely correct that one of the pink wires was on the wrong terminal.Only took me two minutes and all is well now.Thank you, Thank you, Thank you.
        • Roger W.
          • January 29, 2008
          • 572
          Just proves that the membership dues for NCRS are well worth the information that you get from other members who have experienced the same problems that you have or will have.
          • Leif A.
            • August 31, 1997
            • 3656
            Can I get an "AMEN"!!!!
            Leif
