64 parking brake cable clip to brake flange plate - NCRS Discussion Boards
  • Wayne M.
    • March 1, 1980
    • 6414
    Currently dismantling my two complete '64 trailing arm & drum assemblies, for ease of storage and handling; each weighs 50 lbs. Need advice on how to remove this yellow clip. Requires collapse of 3 or 4 spring-loaded legs into the hole, but can only get 2 without the others popping out. I can destroy the clip, but don't know if replacements available. Can't find anything in the P&A catalogs (somewhere under group 4.7xx ?).
  • Harry S.
    • July 31, 2002
    • 5305
    Re: 64 parking brake cable clip to brake flange plate
    Wayne, take a small garden hose clamp and put it around the yellow clip. Tighten the hose clamp until the 4 prongs are depressed then push the yellow clamp into the hole. When the four prongs are in the hole remove the garden hose clamp.
      • 6942
      Wayne, Another way is find a piece of copper pipe or pipe, I think its about 1/2" and push over the clip. this will depress the clips, or take a flat blade screw driver and put side pressure on cable and release one tang at a time while pulling.
      • Wayne M.
        • March 1, 1980
        • 6414
        Got it off -- thanks for the tips, guys. Ended up using a piece of PVC (?) hose that was laying around. Slipped it over the cable and clip. Pipe was not stiff enough on its own to fully retract the 3 clips, but with aid of needle nose pliers squeezing at the raised bumps in the pipe, while wiggling the cable casing, out it came . Hopefully the other side will go as well.
        Bonus item in pic: probably the original Jan '64 rear brake line hose, with the single crimp and the C-clamp in the circumferential slot.
        • Michael H.
          • January 29, 2008
          • 7477
          Wayne
          Is that chassis black on the parking brake cable?
          • Wayne M.
            • March 1, 1980
            • 6414
            Originally posted by Michael Hanson (4067)
            Wayne
            Michael -- I was thinking of you as I dismantled this Jan '64 trailing arm/brake drum assy. Man, .... chassis black is almost everywhere ! Extremely thick in places (dried with a crinkle pattern), yet other spots missed entirely.
            You may recall this is off a California '64 (4.56). EBay seller (to me) bought in 1968, before moving from CA to Klamath Falls OR with the intention of installing the independent rear in a thirty-something Chevy, but never got around to it. Just gotta post this picture of when I picked it up in spring 2005. I loaded it into the wife's '92 Mustang. Note: that's the seller in the photo, not me.
            So the parts were in service about 4 years max, and it shows. Below are 3 pics I took for previous threads. Now that I've dismantled, the blackout is more evident and I will take more. The bare metal areas are where I put Varsol on a rag, just to see what was underneath -- virgin steel.
            Notice in the 2nd pic; look closely and there's a band of white paint on the forward part of the T/A, then covered with blackout. The only other place I've seen this is on Burrough's 396 at NCRS National in St.Louis. I have a picture somewhere. Believe you may know a thing or two about this car .
            • Michael H.
              • January 29, 2008
              • 7477
              Thanks Wayne. Great pictures.
              I wonder what the judges would think if they saw chassis black on the first 6" of the parking brake cable as it exits the brake backing plate on a restored car?
