1965 Washer Motor Removal - NCRS Discussion Boards
  • Steve H.
    • February 13, 2014
    • 3
    What's the best way to remove the washer motor in a 1965 ? I've been told the dash must be removed.
    • 6960
    Re: 1965 Washer Motor Removal
    Steve are you removing the wiper motor or washer pump?? The glove box removal is necc. for the motor removal, you can access the linkage clip and 2 of the 3 bolts of the motor when glove box is out of the way, final bolt is under dash on the drivers side above heater box . If you just to remove the washer pump that can be accessed from out side. I am hoping you do not have A/cond.
    • Steve H.
      • February 13, 2014
      • 3
      Thanks for the information. Very helpful, but I do have A/C. Any other advice?
        • 6960
        Steve, there maybe a duct on drivers side that needs removed
        • Steve H.
          • February 13, 2014
          • 3
          Thanks again for your help.
