Wire Shields - NCRS Discussion Boards
Wire Shields
  • Joseph C.
    • March 12, 2007
    • 31
    Wire Shields
    I been cleaning up the engine compartment on my '65 coupe with factory A/C and have decided to make it look "right" and install the spark plug shielding. Do the front right plugs, #2 and #4 have the shielding over them? If so I'm guessing it's a B**TCH of a pain to do. Thanks your and answers.
    Joe
    • 6956
    Re: Wire Shields
    Joe, Maybe you can loosen the compressor and slide the adjustment forward as far as you can, hopefully that will give some extra room to slide the shied in. I am not sure which mid year is worse a 63 with A/C or even without A/C it a one piece right shield and a bear to remove and install.
