Documentation preservation opinions - NCRS Discussion Boards
  • Brad H.
    • January 27, 2009
    • 250
    Guys,
    This is just an opinion question. Maybe some of you have experienced this and I just wanted some thoughts on it. My Order Copy (Tank Sheet) is really decayed. You can still read it but it's very old, brown and tattered. I'm afraid it will just come apart any time. I was thinking of having it laminated. Does that somehow destroy it's value or validity? Seems to make sense to me but it could be a real no-no as far as I know. I appreciate any thoughts on this kind of thing you may have.
    Thanks as always,
    Brad
  • Michael J.
    • January 27, 2009
    • 7145
    Re: Documentation preservation opinions
    Mine from my '67 is also pretty old and tattered. But, I was told by some dealers not to laminate it. So, I just got a plastic sleeve and put it in, sealing up the end with scotch tape.
    • Leif A.
      • August 31, 1997
      • 3644
      Brad,
      Mine came to me laminated but I think I'm OK and here's why. The lamination process that he used, and that I have used in the past at FedEx office, does NOT stick to the paper. The only thing that sticks together is the laminating material on the outer edges making a nice, air tight package for your valuable docs...IMHO.
      Leif
      • Paul J.
        • September 9, 2008
        • 2091
        I've seen people use this method to keep documents that need to be closely examined from time to time. The sleeve allows someone to remove the document to look at it. If you laminate it then you can't look at the paper closely. I personally don't see a problem with laminating it, but it may make it impossible to determine authenticity. One thing that I have done in the past is to use rubber cement or a glue stick to stick a document to a piece of paper as a backer sheet to keep all it together. Obviously you don't want to do this with a document that has writing on the back or one that has a high value.
        • Paul O.
          • August 31, 1990
          • 1716
          Brad
          This has been discussed before. If you laminate paper you will have zero options in the future. 10 or 15 years ago I had my gas tank build sheet conserved by a paper restoration and preservation company. I used my local history museum to locate this company. The museum uses this company for all the paper preservation. They cleaned the paper and used various solutions to preserve it then it was placed is a special pouch with clear Mylar to view it. That would be my recommendation.
          • Michael G.
            • March 2, 2008
            • 485
            Brad, The first thing is to take many Hi-quality digital photos that will preserve what you have. You can do many enhancements with these and work towards creating the best possible copy. Then preserve the original.
              • 3416
              Hi Brad,
              I agree with Paul that laminating your document isn't too good an idea.
              I went to a reputable framing shop and asked for information on buying archival plastic sleeves to keep the tank sheet and window sticker in.
              They really aren't much $ at all.
              The documents are just loose in the sleeve but that hasn't seemed to be a problem. The sleeve holds them firmly enough so they don't slide out if I'm looking at them.
              They'll soon be in the sleeves for 20 years and don't seem to be degrading at all. They are kept in a binder so light isn't an issue. I'd think that could be, so be careful about light too.
              • Brad H.
                • January 27, 2009
                • 250
                Thanks to everyone for your thoughts. I'll look into some better preservation options as you recommended. Glad I asked before I laminated. No turning back after that!
                Appreciate it!
                Brad
                • Gary C.
                  Administrator
                  • October 1, 1982
                  • 17771
                  Paper document storage sleeves and cardboard backing should be "acid free". Acid free sleeves and backing cardboard are available and easily found at comic book stores or at archival document supply
                  Gary
                  NCRS Texas Chapter
                  https://www.ncrstexas.org/
                  • Brad H.
                    • January 27, 2009
                    • 250
                    Thanks Gary, I'll make sure of that'
                    Brad
