67 and C2 Rear End Housings date stamping - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 408
    Hi
    I've seen C2 rear end housings with date stamps on only the left half side of the lower flange and stop at the casting parting line,and have seen many that cover the entire lower flange. Is any of these two configurations considered more typical, or is it considered that if the date stamp is anywhere on the flange, that it is considered acceptable? I know this isn't a judged feature, just trying to understand what is considered typical.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 67 and C2 Rear End Housings date stamping
    I can't say I've ever seen a C2 stamping that extended past the casting parting line, but I can see why the C3 version would grind the raised cast line off (to get a good impression in the metal), and I surmise that this is why they kept the stamping to the driver side carrier flange for the C2's. The C3's added the numeral before the ratio/posi-non posi code (shift ?), as well as the "W" for plant source (Warren), so there just wasn't enough room.
    • Henry A.
      • May 31, 1990
      • 107
      Just curious, I did not know that the date code on the diff was not judged. My 67 was built in March with an October date on the rear end housing. I am thinking it was a warranty replacement, but can not verify. All other dates aqre correct.
      Looking for opinions, should I search out and re ace the housing with a date correct unit, or leave it as it is?
      Henry Atsma
      54 White/Red
      63 Red/Black SWC
      67 Elkhart Blue/Black BB Roadster
      91 Black/Red ZR1
      96 CE - LT4
      07 Red/Tan
        • 6960
        Henry, Generally the complete rear diff. w/case is not replaced under the warranty , most of the time its generally the internal parts, un-less the case was destroyed , but have never seen this. and if the case was replaced I doubt there would be a hand stamped date .only a casting date.
        • Henry A.
          • May 31, 1990
          • 107
          Interesting. Looks like I may try to find a correctly dated BB rear housing. Thanks for the input.
          Henry Atsma
          54 White/Red
          63 Red/Black SWC
          91 Black/Red ZR1
          96 CE - LT4
          07 Red/Tan
