CE Replacement Engine ID - NCRS Discussion Boards
  • Peter L.
    • August 31, 1995
    • 26
    Car is a 1961 corvette F.I. model. Original short block was replaced under warranty with a 3959532 cast block assy. which is stamped as CE4N34145 . Bottom right side of the block is hand stamped with the following numbers; S 374164. What does this number mean? Second question: bottom flange inline with each cylinder is stamped with a letter, i.e. J or K. What does this mean?
    Any information would be appreciated, thank you
    • 15640
    Re: CE Replacement Engine ID
    In your case Pete I cannot tell you about the stamped numbers, but the letters on the oil pan rail are indicative of the exact cylinder size. After cylinder honing an air gauge precisely measured the cylinder bore diameter and gave the operator size readings that he stamped on the pan rail. These sizes were transmitted to the piston assembly area, along with precise crankshaft rod diameter. The piston/rod assembly area then matched piston sizes with rod bearings to selectively fit the piston/rod assembly to each specific cylinder/crankshaft combination. This obviously was a very labor intensive operation. Both Flint Engine and Tonawanda used this method of engine assembly for over thirty or forty years and many millions of engines.
    More recently, perhaps in the 1990s machining operations became much more precise and today engine assembly involves putting any piston in any hole and as a result robots often handle that task at many engine assembly plants.
    • Michael W.
      • April 1, 1997
      • 4290
      Peter-
      The CE program did not start till 1968. The 4 after the CE typically indicates that the engine was assembled in 1974.
        • 15640
        Originally posted by Michael Ward (29001)
        Peter-
        Good point Mike. It would be interesting to know the date code on the cylinder case.
        • Peter L.
          • August 31, 1995
          • 26
          Terry,
          Can you elaborate on where to find the date code on the cylinder case?
          Peter
            • 15640
            Terry,
            Peter
              • 43287
              Peter-----
              I don't think this was a warranty replacement. GM block casting 3959532 was a block used for SERVICE-only 283 cid engines. However, that casting number did not exist until very late 1968 or early 1969. That would have been long after the warranty on a 1961 Corvette expired.
              • Jim T.
                • March 1, 1993
                • 5351
                Peter-
                I have a warranty replacement short block installed in my 1970 Corvette in August 1970. CEOA 47538 block #3970010 D260. This block replaced the V0702CTG engine block that only lasted a few minutes in my new 1970.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  This urbal myth that CE meant a defective engine replaced under warranty, as the preceeding details attest.
                  It will be extremely rare occurances - most of these were simply blown engines replaced later on with something manufactured by CE Chevrolet Engine.
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    Ronald
                    You are exactly right. The CE stamp does not necessarily mean that the block was replaced under warranty. I think a lot of folks are confused on this. All partial engine assy's after some time in 1968 had the CE stamp.
                    • David L.
                      • July 31, 1980
                      • 3310
                      Back in the early 1980's Dobles Chevrolet in Manchester, NH, had a NORS 283 engine assembly for sale with the following numbers:
                      Cast. # "3959532"
                      Cast. date "I 23 5" (Sept. 25, 1975)
                      Stampings on the pad: "CE6N23636" ("CE6" = Chevrolet Engine, 1976)
                      and "S0428XCA" ("0428" = April 28th)
                      Dave
                        Cast. # "3959532"
                        Dave
                        Dave -
                        That was a "universal replacement" 283, made at the Saginaw Service Engine Plant.
