1962 pulley fan clutch assembly
Re: 1962 pulley fan clutch assembly
Dino,
The fan blade and pulley appear correct. Some fan blades are longer so only a measurement would confirm; however the configuration is correct. The fan clutch is very similar to mine but the center portion outside of the spring is generally flat on all the 62 clutches I am familiar with. I can send a photo later if no one else jumps in first.
Larry- Top
Dino,
The fan has the correct domed rivets and should measure 8 9/16" from the center hole to the tip of each blade (17 1/8" dia.) for the 62 Corvette. The Chev. passenger cars with AC used a similar fan but the diameter was 18" or 9" from center hole to blade tip.
Dave- Top
My early 62 #29 looks like this. Hard to take a good picture.Attached Files- Top
John picture is of an early 62 (60 & 61) clutch. Sometime before mid year the little spring in the center disappeared. Some say that the OP picture is of a late 62 clutch. Many said it never appeared in 62. I have 2 mid to late 62s with very original engine compartments that both have the lumpy face of the OP picture. There is another thread about this about a year ago.- Top
Robert,
I don't understand. Are you saying that between the 1961/62 early clutch with the thermo spring totally exposed on the center face, and the later 1962 clutch with the thermo spring recessed in the face segmented "doughnut", that there was a clutch that had NO thermo spring at all? Explain please.
Save the Wave ............ JGM- Top
