seatbelt installation in a 64 coupe - NCRS Discussion Boards
  • Ron T.
    • January 21, 2014
    • 35
    Is it hard to install seatbelts in a 64 coupe? Don't see anything to fasten them to.
  • Harry S.
    • July 31, 2002
    • 5330
    Re: seatbelt installation in a 64 coupe
    Ron, all 64's came with seatbelts. The only way there would be nothing to attach them to is as if someone on purpose drilled the rivets from the brackets and closed the fiberglass.
    Else, look under the car for the brackets. Also, pull the carpet back from both rear side positions of the seats and look for the holes.
    There was a thread on this about 4 months ago, search the archives.
    If all the brackets are there and with good thread all you need is the belts and the four bolts.
    Cheers..
    • Ron T.
      • January 21, 2014
      • 35
      Harry thanks for the reply. I finaly found the holes for the bolts. Threads appear okay, ordered the bolts the other day .Thanks Ron
