My fuel gauge is not working. Should the gauge be grounded to the gauge housing? I installed a new temp. gauge along with the housing. After re-installing both gauges I discovered that when the key was turned on both gauges pegged and I could hear a clicking noise coming from the sender. I removed the fuel gauge and installed an isolator so that the gauge would not contact the housing. I checked both gauges with an ohm meter and found no ground continuity between the terminals and housing. I started the engine and could see that the temp. gauge was working, but not the fuel gauge.
Mike
Mike
