1971 Fiber optics Repair - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 478
    I have one fiber optic cable on my car that has about a foot missing off one end. Is there someway to repair this or do I have to replace the full line. If so where can I get a replacement line for this. There is nothing wrong with the harness and I am going to rewrap it anyway. I called lectric limited but all they have to sell is a complete wire harness. Any help greatly appreciated.
    Sheldon
  • Jerry B.
    • August 31, 1994
    • 416
    Re: 1971 Fiber optics Repair
    Check with some of the parts houses that sell used parts.
      • 3416
      Hi Sheldon,
      Do you have the original ferrule and lens that was on the end of the cable you're repairing?
      The size of the cable and thus the ferrule and lens varied depending on where it was used.
      For instance the cable, ferrule, and lens for the front parking lights are larger than the cable, ferrule, and lens for the tail lights.
      The vendors as Jerry posted have the parts but make sure you order the right ones for your cable's use.
      Good Luck!
      This is the larger size for the front parking light.
        • 43248
        Sheldon------
        A firm by the name of Street Specialty Products supplies kits for fiber optic repair. They may also sell lengths of the fiber optic cable.
        • Sheldon S.
          • March 1, 1999
          • 478
          Joe,
          Is street specialty in Georgetown, that is all I could find when I googled that name.
          Allan, I do not have the cutoff piece so will need Cale and ends. Gonna try this place Joe just mentioned.
          Thanks everyone.
          sheldon
            • 43248
            Originally posted by Sheldon Sands (31959)
            Joe,
            Thanks everyone.
            sheldon
            Sheldon------
            All I recall is that they were somewhere in the mid-Atlantic area. So, Georgetown, Delaware sounds about right.
            • Paul O.
              • August 31, 1990
              • 1716
              Zip also sells repair kits have never used their kits but here is the page.
              http://www.zip-corvette.com/GroupDetails/SubGroupResults.aspx?gid={55660b24-aec5-487d-9b82-34d4c41d8735}&SearchType=_GROUP_SEARCH&GroupName=6 8-71+Fiber+Optics+%26+Repair&
              • Terry B.
                • August 31, 1999
                • 607
                Hi Sheldon,
                I tried to repair a number of cut fiber optic lines when I first took ownership of my '68. The results of the repairs were not very good so I ended up buying another front wiring harness from Lectric Limited. You might have much better luck with just one to repair. If the repair does not go well, you should be able to buy another optic line. If I remember correctly, I used Zip, as Paul mentioned earlier, for the repair splice. Good luck.
                Terry Buchanan
                Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
                Corvettes Owned:
                1977 Coupe
                1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
                2003 Electron Blue Coupe
                2019 Torch Red Grand Sport Coupe
                • Dick W.
                  • 10483
                  We successfully repaired several cables. Used a single edge razor blade to square the ends of the break, cleaned the ends with a quetip and alcohol, used heat shrink tubing to secure the splice. Just take patience and a little time
                  Joe, et al, think Bruce Street went out of business several years ago. He had the first door hinge springs that I ever saw
                  Dick Whittington
                  • Bob H.
                    • July 31, 2000
                    • 821
                    If you don't want to tackle it, find a telephone or network cable installer/ repairman. Most all should have experience repairing fiber. My techs were all trained to do so. They may also be able to provide a scrap piece of fiber.
