dash cluster - NCRS Discussion Boards
dash cluster
  • Bill M.
    • 1328
    dash cluster
    I have painted mid year dash clusters in the past. but i cant remember how i protected the small letters around the ignition, head lights ect... do i just paint over and wipe off or do i try to apply a coat of wax? cluster is out of car and completely appart.
    Bill
  • Bob H.
    • July 31, 2000
    • 821
    Re: dash cluster
    Hi Bill:
    Long before computers and access to NCRS members, I painted a couple of dashes. I used a toothpick to spread vaseline on the letters, etc, painted it and let dry then simply wiped off the letters. I'm sure there may be updated ways but it worked for me back then
    Bob
    • Harry S.
      • July 31, 2002
      • 5330
      Re: dash cluster
      Bill
      Bill, I just did the bezels for my 63 radio. I cleaned them with acetone then painted everything. When it was dry I took a new sharp razor and just scraped the paint away. At the shop we use the same approach with the entire cluster.
      • Bill M.
        • 1328
        Re: dash cluster
        Harry Bob
        Thanks i will do this weekend
        • Domenic T.
          • January 29, 2010
          • 2452
          Re: dash cluster
          Bill,
          I did my 67 and used acetone and a Q-tip lightly to remove the paint from the letters and other places.
          I found that stretching a cloth over my finger worked better because the Q-tip would hold to much and could wash away to much, as the cloth seemed to hold the right amount of acetone.
          DOM
          • Bill M.
            • 1328
            Re: dash cluster
            Thanks Dom
            Acetone is the winner
            • Ralph E.
              • February 1, 2002
              • 905
              Re: dash cluster
              Bill, I just did the cluster on my 67. I painted everything. When it was dry I took a new sharp exacto razor and just scraped the paint away. Worked like a charm.
              Just take your time, no need to rush.
              • Bill M.
                • 1328
                Re: dash cluster
                ralph thanks
                • Brian K.
                  • September 19, 2007
                  • 174
                  Re: dash cluster
                  I have always painted and carefully with a rag wet with lacquer thinner on my finger wipe it off.
                  66 Coupe
                  66 Convertible
                  2022 2LT Coupe
                  67 Chevelle SS396
                  67 XLCH HD Sportster
                  • Michael M.
                    • February 7, 2011
                    • 186
                    • Donald O.
                      • May 31, 1990
                      • 1591
                      Re: dash cluster
                      Ralphie,
                      Did you use SEM Trim Black, or something else.
                      DonO
                      • Donald O.
                        • May 31, 1990
                        • 1591
                        Re: dash cluster
                        Originally posted by Michael Mayland (52812)
                        There is really no need to mask or scrape. I’ve had great success wiping with lacquer thinner to clean paint off of clusters, grilles, etc.
                        After painting, I let the paint set up for about 5 minutes. I wear rubber gloves, then tightly wrap a cotton T-shirt around my finger. Momentarily dip the cloth in lacquer thinner, you don’t want it dripping wet. Then wipe the surface where you want to remove the paint. Just be a little more careful on the letters, lightly wipe don’t push. You’ll need to wipe surfaces several times, moving to clean areas on the cloth. Try it, it works well. This is a pic of my ’67 cluster after using this method.
                        Looks great!
                        How did you protect the turn signal lenses, and other idiot lights between the tach and speedo?
                        • Tom R.
                          • December 20, 2010
                          • 177
                          Re: dash cluster
                          Careful with the blades. Some of those old letters and bezels have all aged and become brittle. They may even be a little flaky. Too much pressure with a blade could have negative results. I have always used the lacquer thinner trick. It works.
                          Tom
                          • Bill M.
                            • 1328
                            Re: dash cluster
                            Don
                            you have to remove everthing the turn lens ect... come out easily
                            • Ralph E.
                              • February 1, 2002
                              • 905
                              Re: dash cluster
                              Originally posted by Donald Olson (17357)
                              Ralphie,
                              DonO
                              Don,
                              I used SEM Trim Black.
                              Cleaning off the chrome around the bevels and script was a piece of cake.
                              One note: if you use the 1/4" rod method to reinstall the cluster be very careful not to scratch the paint around the cluster attaching bolts or you will need to do a little touch up around the holes. Lesson Learned!
