trailer door question - NCRS Discussion Boards
  • Michael F.
    • 745
    for a 20' enclosed trailer, for the side door which is more secure....cam lock bar or the flush camper style lock with key?
    also how far apart should d rings be and how far back from front and rear of trailer, don't like the way the track bar on floor attached, looks like screws hold it down, also seems like if car moved back and forth for any reason, attch in track could come loose.
    Michael
    70 Mulsanne Blue LT-1
    03 Electron Blue Z06
  • Gene M.
    • April 1, 1985
    • 4232
    Re: trailer door question
    Mike,
    I would prefer the lock bar with a pad lock same as flop down door. What is track bar you refer to on the floor? My trailer has "D" shaped flush loops in the floor. They are sandwiched with a lower plate and mounted with 5/16 or 3/8 bolts. They are spaced about 3 1/2 feet apart. As far as placement that should depend on the trailer wheels placement and tongue length to get the proper tongue weight. I use fixed curved wheel chucks in the front to stop the Corvette in the same place. Set straps straight in the front and crossed in the back.
    • Dick W.
      • 10483
      My preference is E track. No worries about spacing
      Dick Whittington
      • Michael F.
        • 745
        E or L track is what I was referring to I believe, like in aircraft for cargo. This will be for a 20' well cargo with 3500 lb axles, that is all I need for my corvettes. Within my budget and will never buy any cars again, retired now and every penny counts....Dick are you hooking to factory slots on frame or ???...thanks
        Michael
        • Richard L.
          • May 31, 1988
          • 156
          As usual, Dick W. is spot on...
          Use E-Track and Wheel Nets and let your car ride on its natural suspension... I don't even have D-Rings in my trailer... Also get some E-Track Idler Fittings to keep the ratchet straps away from your fiberglass... http://www.macscustomtiedowns.com/product/26/ETrack
          Cam Lock for the Door... Hands Down the Best Security...
          Hope this Helps...
          Rick
          • Dick W.
            • 10483
            Use the factory slots. Bought the straps http://bit.ly/MBOZSB
            Dick Whittington
            • Michael F.
              • 745
              thanks, had cam locks on my previous trailer 15+ years ago and liked them. Will look into getting the E tracks also.
              Michael
              • Jim S.
                • March 13, 2013
                • 360
                Hope this Helps...
                Rick
                E Track works great with the idler fittings. With stock wheels on a C2, the track width from center of tire to center of tire is 57" Mount the E Track centered at that same distance apart to best use wheel nets.
                The E Track will also serve as a guild if you have someone directing your drive into the trailer
                • Ed N.
                  • May 16, 2010
                  • 1003
                  E-tracks are the way to go. Here is the setup I use. It's not the best in the world, but gets the job done for me. I use straps that have the idler built into it for e-tracks and is designed for very low cars (see attached pictures). 554340_4434917670913_298865969_n.jpgTrailer%20Tape%202.jpg large_552308_etrack_straps_012.jpg
                  Ed Nieves
                  NCRS #51799
                  • Dick W.
                    • 10483
                    I installed my tracks on 48" center. I personally do not like to drive over the tracks. I like the idler so that the straps do not get close to the lower valance on some of the cars. Rear, when attaching to the factory tie down slots, no problems. I also have e track on the side walls, allowing me to fasten gas cans, tool boxes, luggage, etc.
                    Last two trailers I have installed e track about 5' above the floor along the side walls. Using logistic bars with a plywood floor installed, I can store smaller items overhead. When I was showing the L/88, I hauled in in the parts trailer with boxes of parts stored overhead of the car.
                    Dick Whittington
                    • David K.
                      • September 30, 1979
                      • 241
                      Ed, nice pics. What trailer mfg. do you have. looks real nice.
                      Dick, Do you have pics of your set up too ??
                      Dave
                      • Dick W.
                        • 10483
                        Dave
                        Dave, no photos and trailer is loaded floor to ceiling, front to back, with items for our next auction. Sorry.
                        Had this trailer almost three years and only hauled one car, Kermit, back from the body shop
                        Dick Whittington
                        • Ed N.
                          • May 16, 2010
                          • 1003
                          David, it's a 20 foot slope nose from Trailer World. Here is the link: http://www.trailerworld.com/2014-uni...wr-n9h|am.html
                          I dealt with Keith (great guy). These people are very reputable. They are located in Bowling Green, Kentucky. Oh, here is a different angle of the trailer.
                          Ed Nieves
                          NCRS #51799
                          • Dick W.
                            • 10483
                            [ATTACH=CONFIG]51325[/ATTACH][ATTACH=CONFIG]51326[/ATTACH]
                            I have purchased several trailers from them, beginning in 1984. 44' gooseneck car/vendor trailer, 35' equipment trailer, 26' stock trailer, 10 ton dump trailer, slant load three horse trailer, and sent several friends there to buy trailers. Unfortunately the trailer I have now is not the quality that they sell, I needed a trailer to move an estate I bought and ran into a guy with a trailer that was 18 months old and needed cash ASAP. If I were buying a new trailer for any purpose they would be my first choice.
                            Dick Whittington
