Wheel weights without grams - NCRS Discussion Boards
  • Wayne L.
    • September 30, 1981
    • 233
    I am looking for correct wheel weights, i.e., no grams. I seem to remember advertisements in the Driveline, but didn't see an ad in this latest issue. Does anyone have contact information on where to get them?
    Thanks, Wayne
  • Paul S.
    • June 30, 1982
    • 356
    Re: Wheel weights without grams
    paragon has them,,,,,,,,,,,,https://www.paragoncorvette.com/p-34...el-weight.aspx
    • Paul D.
      • January 1, 1988
      • 101
      Check on Ebay......you can "tap" down the gram fonts with a small hammer,lead is soft,leaving only the OZ font.....Or you can go down to your local tire repair and get some used Micro weights.....Still may be some points off due to original configuration wings on weights......Put the best one's on your spare......
        • 15610
        I remember a Restorer article of a few years ago in which Gary Beaupre identified seven (I think) different brands of wheel weights that were used on Corvettes. Don't be fixated on the MICRO brand. There were many others. As John inckley pointed out:Chevrolet was using wheel weights by the many millions per day. One source could not have even come close to supplying all of them.
        • Joe M.
          • April 30, 1990
          • 1338
          Wayne, send me a PM. I think I have several that I would part with.
          • Gary B.
            • February 1, 1997
            • 7046
            Paul,
            The Paragon wheel weights are modern versions that differ in two ways from 1960s-era weights. First, the new version has the value in grams on one end, which isn't correct. The ounce value should appear on both ends. So, the idea of peening down the gram value won't work, since that will just leave a mushed surface with no ounce value. Also, original Micro weights had the "bird wing" design, which the modern ones don't have. In my opinion, finding period-correct used weights is better than buying incorrect new weights. NOS Micro weights show up on e-bay fairly often. For C2 cars, just don't get ones that were x.25 or x.75 ounces, since they weren't used on the production line. x.25 and x.75 weights were available in service, but that won't pass muster with knowledgeable judges.
            Gary
            • Gary B.
              • February 1, 1997
              • 7046
              I remember a Restorer article of a few years ago in which Gary Beaupre identified seven (I think) different brands of wheel weights that were used on Corvettes...
              Terry,
              I don't have my article handy to check, but I seem to recall there were 5 vendors.
              Gary
              • John T.
                NCRS Financial Officer
                • January 1, 1983
                • 292
                To add to Gary's comment about C2 wheel weights. The x.25 and x.75 were not used on 61-62 either.
                John
                • Wayne L.
                  • 233
                  All-
                  Thanks a bunch for all of the information, Wayne
