1963 Oil Drain Bolt Head Marking - NCRS Discussion Boards
  • Henry A.
    • May 31, 1990
    • 103
    What is the correct head marking for a 63 300HP oil pan drain bolt.
    The JM indicates a 3/4 inch "M" hex head bolt. A major parts supplier only lists a bolt that is larger and the head is marked by an "A" with a circle around it.
    Thanks for your knowledge.
    Henry Atsma
    54 White/Red
    63 Red/Black SWC
    67 Elkhart Blue/Black BB Roadster
    91 Black/Red ZR1
    96 CE - LT4
    07 Red/Tan
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 1963 Oil Drain Bolt Head Marking
    Henry,
    Most of the 63 drain pan bolts have been "AP" that I have seen however "AP" was only one of several suppliers for the C-2's. "TR" bolts have been used as well as the "A" bolts you mentioned on 63's.
    JR
      Henry -
      The JG is wrong - the drain plug is 7/8" hex.
      • Henry A.
        • May 31, 1990
        • 103
        Thanks Joe and John.
        Henry Atsma
        54 White/Red
        63 Red/Black SWC
        91 Black/Red ZR1
        96 CE - LT4
        07 Red/Tan
        • Joe R.
          • July 31, 1976
          • 4551
          JG wrong! No way! I got docked in 93 because my plug was not a 9/16"!!! It wuz one of those big ones. Reasoning was that it had been stripped out and somebody put in one of those big ones! Go figure!
          JR
          PS. Henry, go with one of those big ones! AP, A or TR will get you points. Not deducts! That is if they have revised the JG-finally!
          • Wayne M.
            • March 1, 1980
            • 6414
            Originally posted by Joe Ray (1011)
            Henry,
            Most of the 63 drain pan bolts have been "AP" that I have seen however "AP" was only one of several suppliers for the C-2's. "TR" bolts have been used as well as the "A" bolts you mentioned on 63's. ..
            Joe -- This 7/8" 'circle A' has a magnetic tip. Was that original for a C2-era ?
            c
            • Michael H.
              • January 29, 2008
              • 7477
              c
              Wayne
              I think the drain plug with the magnet was only used for big block. Possibly 65-67, or later?
              I think older parts books show the two different numbers for small block and big block.
