63: Trick to insert clip on master cilinder - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12868
    Any trick to insert he clip (2nd from the left) into the master cylinder? It tried several times but it flies off all the time I try to compress it to insert...
    Rob.
    NCRS Software Developer
  • Harry S.
    • July 31, 2002
    • 5344
    Re: 63: Trick to insert clip on master cilinder
    Rob, I cut a short wooden dowl. Then I compress the spring in the MC with the dowl and a C clamp.I align one end of the clip with the slot then hold in plece as best I can with a finger and work the other end in with a short needle nose plyers till it sets in place.
    Hope that all translates well!
      • 6957
      Or just clamp Master Cyl. in vice and used a Phillips screwdriver, the clip can be installed with your fingers once the piston is pushed in slightly.
