Correct flywheel bolts - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    My 65 BB Had a heavy flywheel with two different length flywheel bolts holding it on . I went downstairs to my parts dungeon and had three different lengths of flywheel bolts . A 15/16,13/16 and a 11/16 thread length .I bought a new GM lightweight flywheel , what is the correct thread length bolt for a light weight ?
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Correct flywheel bolts
    Bill,
    I don't know the answer to your question, But I can tell you the bolt should stick thru about 2 threads on the other side of the crank flange when tight.
      • 43246
      Bill------
      I recommend using NEW flywheel bolts. The GM part number for ALL Corvette manual trans flywheel bolts is GM #839756. GM says this bolt is 7/16-20 X 1". However, the actual bolts might measure + or - 1/16". They do have an unthreaded shank below the bolt head and this is important.
      While new GM bolts are very adequate, I use only ARP flywheel bolts. These are ultra high quality and that's what I want for bolts like this.
        I've always used ARP flywheel bolts also; note that they are a thread or two longer than the GM bolts and may require a slight "adjustment" of the sheet metal inspection cover to avoid contact.
