Anyone know the difference between the clips used to secure the dash wiring harness to the cross brace bar and the clips used to secure the power window wiring harness to the brace bar for a 66 (assuming 63-67 are the same)? If I'm looking at this correctly, AIM shows 3827371 for one and 3714454 for the other? Also how many of each should be used? From the AIM it looks like only 2 or 3 for the main dash harness and maybe 3 or 5 for the power window wiring.
Under dash clips for dash and p/w wiring
Re: Under dash clips for dash and p/w wiring
Alright I got a couple of pics of some clips. First is of the 3827371 clip which was used (at least for my 66) for the wiring harness under the dash on the crossbar, headlight wiring running down the radiator support, windshield washer hose on the hood latch, radio antenna cable under the dash. The second is a clip (maybe 3714454) used for the power window harness under the dash, and the 67 speed warning wiring under the dash. Does the second clip look right for the power window harness, I'm not sure?- Top
