Trying to buy new stock front springs, 1963 - NCRS Discussion Boards
  • Steve G.
    • May 31, 1994
    • 230
    Looking to buy new 1963 front springs. i dont want "touring" springs (460 lb) or Gymkhana springs (550 lb), I want the stock soft 293 ones. Nobody lists them. Some retailers (Paragon, CC, Long Island) list "stock" or "STD" springs at double the 460/550 price, but will not clarify what the rate is.Why is this so hard? Where are people buying stock rate springs?
  • Joe R.
    • July 31, 1976
    • 4551
    Re: Trying to buy new stock front springs, 1963
    Steve,
    The 1963 Standard Spring was a one year only spring. It changed in 1964. Nobody is going to make a one year only front spring for a 1963 automobile. You will be best served by finding a good used set. The retailers want to sell you what they have and not what you want.
    JR
    • Steve G.
      • May 31, 1994
      • 230
      Hi JoeThanks for your response, fair enough. However, Im more interested in proper ride height and soft ride rather than an absolutely correct '63 spring. That being the case, do you know who sells the closest thing to a replacement for the 293 lb spring as opposed to a 460 Tourning or a 55 Gymkhana even if its "correct" for 64-67?
      • Timothy B.
        • April 30, 1983
        • 5198
        Steve,
        To answer your question I would say LI Corvette. That's where I bought mine and they are the same wire diameter as the originals and one turn longer. So instead of seven coils there are eight if I got that right, the ride height rose about 1/2" from where it was before so it's the same IMO.
        Don't take my word for it, call and talk to them first before buying. Do you still have the original springs for the car, how much rust etc.?
        • Steve G.
          • May 31, 1994
          • 230
          Call and talk to people from Long Island Corvette? Uh, I'd rather not thanks. I'd order there but a conversation never seems to be a good idea.The springs on the car have rubber spacers on them propping them up. They look like they need to be replaced no matter what. Im not sure if they are original.Are the springs you bought from LI approximately the same (soft) ride? I'm concerned that the 460 Touring that everyone is selling as a replacement is too harsh. I just hate a harsh ride.
          • Harry S.
            • July 31, 2002
            • 5333
            Call the folks at Eaton.....
            The leading manufacturer of leaf and coil springs for the street rod and restoration automotive industries
            • Steve G.
              • May 31, 1994
              • 230
              Emailed them Harry, thanks.The choices appear to be: Long Island, 15" (stock), 293 lbs (I think), $170orThe 460 lb a bunch of people sell, 13" (slightly lower) but stiffer than stock, $80.
              • Steve G.
                • May 31, 1994
                • 230
                My answer from Eaton:Steve, Sorry, at that is available with us, as with all vendors that I know of is the Heavy duty. I do not know where or if the standard springs are available.Zero help from any retailers on thsi.
                • Michael H.
                  • January 29, 2008
                  • 7477
                  Steve
                  It probably won't help but mention to Eaton that the original print for the base 63 spring is available. (I think I have the huge 2'X3' print) All of the specs and dimensions are shown.
                    • 43258
                    Steve
                    Michael-----
                    Once-upon-a-time a fellow from Eaton told me that they had the blueprints for every Corvette spring through their GM Restoration Parts license. Of course, that does not mean that they will actually manufacture all of them.
                      • 43258
                      Steve-----
                      I think the 64-67 small block spring, GM #3851100, will work just fine for a 1963 application. However, it's long-since GM discontinued. There's a chance you could find an NOS set, though.
