72 Holes ??? - NCRS Discussion Boards
72 Holes ???
  • Rey S.
    • April 1, 1995
    • 277
    72 Holes ???
    There are 2 holes above the fuse block. The larger hole is 1" dia. and the smaller is 3/8" dia. Any one of our good members know what these holes are used for????? Them AIM is not very clear as to what passes through them. Thanks Rey Stenhouse 72 LS-502 Coupe
  • Bill C.
    • July 15, 2007
    • 904
    Re: 72 Holes ???
    i think the 1" hole is for the clutch rod and boot assembly
    the smaller hole might be for the hood release cable...
    my best guess ...
      • 3422
      Re: 72 Holes ???
      Hi Rey,
      Good to talk to you!
      I believe the hole for the hood release is higher up the firewall and further to the left.
      I believe the small hole is for the rubber plug that secures the left side of the heavy rubber coated firewall insulation blanket. UPC 1 asm, Sheet D9, Item #4.
      There's not another hole on my 7,1 so for the larger one?
      How close is it to the top of the fuse block?
      • Rey S.
        • April 1, 1995
        • 277
        Re: 72 Holes ???
        Hi Alan: Yes it's nice to hear from you, we haven't talked I a while!!!The larger hole is +/- 3" above the upper right corner of the fuse block. Bill C. suggested that it might be for the clutch rod, if so I will plug it as mine is an automatic. I think you are correct about the insulation blanket as the are a string of these holes across the firewall all on the same level. all sounds good but will investigate none the less. I tried to enclose some photo attachment but the page would not load!!!!Thanks for the info.
          • 3422
          Re: 72 Holes ???
          Hi Rey,
          I believe the majority of the small holes you're seeing that are in a row across the firewall are for the carpet installation plugs. The few holes for the 'blanket' are the ones that are a bit higher up the firewall. The heater box helps hold the 'blanket' in place on the right side.
          I'd like to see some pictures of your work!
          • Rey S.
            • April 1, 1995
            • 277
            Re: 72 Holes ???
            Alan -- Thanks for the info -- I will print it out and save it.I would love to send some pics but I have difficulty sending via the NCRS system. I guess I haven't fully learned how to manipulate the system yet, I will keep trying until I figure it out Also with regards to you !!!
