BB a/c adjusting bracket - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I need a little help with my compressor's adjustment bracket. It came with the car, it was the only bracket that did, and I'm not 100% sure it's correct. The pin on the bracket that the compressor rotates on is missing, only the hole is there. Aside from that it appears to be correct. I attached a pic from a vendor that shows it's correct configuration and pics of both sides of mine.
    So is this a correct bracket? If it is, does anyone know what the length and diameter of the missing pin is? Thanks!!
  • Grant W.
    • December 1, 1987
    • 407
    Re: BB a/c adjusting bracket
    Yes correct looking bracket you have.
    Pin is 11/16
    One inch long.
    The long pin goes into bracket 3887166 the long arm of it.....I think.
    If you make a steel pin, make sure it is pressed in and holds firm. Or put it inbetween a vise and squeeze it in. Make sure the pin protrudes the same side as the repop you have pictured.
    Hope this helps.
    Grant
    • Tom L.
      • October 17, 2006
      • 1439
      Thanks Grant, just one thing to clear it up. Is the total length of the pin 1" or does it stick out of the bracket 1"? Thanks!
      • Grant W.
        • December 1, 1987
        • 407
        Hi Tom
        024.jpg025.jpg026.jpg Total length is about an inch. That pin goes into another bracket and should not stick out.
        Hope the pictures help.
        Grant
        • Tom L.
          • October 17, 2006
          • 1439
          Thanks Grant, that clears things up nicely. Have fun!!
