890 distributor - NCRS Discussion Boards
890 distributor
  • Kevin M.
    • September 19, 2013
    • 72
    890 distributor
    I'm looking for a 890 distributor (date april or early may 58) for my 1958 230 hp. was the 890 distributor used on passenger cars as well as Corvettes and how would i identify a Corvette distributor?
  • Ruedi K.
    • December 12, 2011
    • 242
    Re: 890 distributor
    1957 Chevrolet Bel-Air 4bbl also used a 1110890 distributor
    There is an example of such a distributor here http://www.ebay.ie/itm/1958-CORVETTE...item58ab0096d0
    It has the hexagonal style vacuum advance (w Delco Remy logo) used on 1958 230HP engines + metal vacuum line with fitting and oiler tube with GITS cap.
    Reference our handy list to find 1955-1962 Corvette part numbers for distributors, caps, rotors, and condensers.
    • Kevin M.
      • 72
      Re: 890 distributor
      Was there any differences between the two distributors?
      • Ruedi K.
        • December 12, 2011
        • 242
        Re: 890 distributor
        Apart from the tag with another date, I can't see any difference. But not for sure.
        • Kevin M.
          • 72
          Re: 890 distributor
          thank you for the replies anybody else know if there are any differences
            • 43246
            Re: 890 distributor
            Kevin-----
            A GM part number defines a specification for a part. So, if the part number is the same, it does not matter which application a particular component was originally installed in.
