1960 clutch rebuild question?? - NCRS Discussion Boards
  • Steve V.
    • June 27, 2011
    • 95
    I rebuilding the clutch in my 1960. It has a diaphragm pressure plate that I had NAPA send off for rebuild along with rebuilt clutch disc and resurface the flywheel. When I bolted the pressure plate up I noticed that there is only about 1/8" of gap before the pressure plate starts applying pressure to the clutch disc. Is this all that is necessary for proper pressure?
    Thanks for the help.
    Steve
    Opportunity is missed by most people
    because it is dressed in overalls and looks like work.
    Thomas Edison
    • 43297
    Re: 1960 clutch rebuild question??
    Steve
    Steve-----
    I would say that's about right.
    By the way, you do realize that a diaphragm-type clutch is not what was originally used for your application, don't you?
    • Steve V.
      • June 27, 2011
      • 95
      Thanks Joe, yes I know it's not original, but it is the one that was already in the car. Is there any reason that I shouldn't use it? They worked OK, but I had the trans out for rebuild and the clutch and pressure plate were scorched so decided to rebuild them while I had the car apart.
      Steve
      Thomas Edison
        • 43297
        Steve
        Steve------
        They'll work fine. However, since you said that you had them rebuilt, I figured you thought they were original.
        • Paul D.
          • September 30, 1996
          • 491
          OK, I'm going to ask what others , I'm sure, are thinking. What influenced your decision to rebuild vs. replace your clutch components? Chip.
          • Ken A.
            • July 31, 1986
            • 929
            Personally, I would not recommend a rebuilt clutch on anything over 100 HP. Just my .02.
            • Philip P.
              • February 28, 2011
              • 558
              I agree with Paul, when I rebuilt the engine(1960) a couple of years back I installed a LUK diaphragm clutch and do use the "Gorilla" spring and works just fine.
              The only issue I have had with the clutch is the bushing on the cross bar to pedal arm, I replaced the rubber one with a oilite bushing.
              Phil
