Today I learned a new way (for us) to remove stubborn oil filler tubes. I am working on an early 63 FI that requires a black painted oil filler tube.
The customers baseplate aka intake had a minty chrome plated one. For the last month or so my helper and I have been messing around with this tube trying to get it out without ruining it.
Finally last week I told him to just trash the tube and get it out and pitch it. Told him to make sure he did not hurt the customers baseplate.
He and I tried all the various ways of getting the tube out. Clamping the baseplate in a 30 Ton press. Using Aero Kroil big time. Lots of heat. Heated the aluminum and tried and tried but the tube wouldn't budge. Someone had pounded it in as far is it would go.
So this morning here is how my helper got the tube out using a new method that he learned from a machine shop.
Laid the baseplate upside down on the workbench. He heated the inside of bottom of the chrome tube until it was cherry red. Then using a thick leather glove he went to yank on the tube and guess what happened. The tube popped out and hit the rubber mat on the floor. Popped right out!!!!!
Impressed the crap out of me as one would think heating the tube would expand it. So from now on we are removing all of the oil filler tubes using that method. Heating the extreme bottom inside of the tube. Yes the baseplate/intake has to be off the engine.
By the way the minty tube was not damaged at all.
CRC no freeze stuff didn't work either. Nothing worked until the new trick above. JD
