67 L71 Engine Pictures - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2012
    Does anyone have any good pictures of a 67 L-71 engine. Does the alternator brace bolt on to the manifold or on to the head? I am trying to identify the various heater hose and vacuum fittings, throttle springs, wire retainers, etc. and some good pictures with the air cleaner removed would give me guidance. Thanks
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11364
    Re: 67 L71 Engine Pictures
    Patrick, If power steering.....Head. If no power steering...IIRC...Intake
    I have pictures if PS.
    Rich
    • Patrick B.
      • August 31, 1985
      • 2012
      Rich
      Power brakes but not power steering
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11364
        Patrick, Then I'm pretty sure it mounts to the intake. There's a boss at the left front for it IIRC. I'm not in front of my '67 AIM but it should be in there. I'll see if I can find some non-PS L71 pics in my files.
        Rich
          Here's a photo of a non-P/S '67 L-71 - the alternator brace bolts to a boss on the front of the intake manifold.
          • Patrick B.
            • August 31, 1985
            • 2012
            Thanks for the picture. Does anyone know whether there are any washers on the exhaust manifold bolts and whether the throttle spring bracket is bare metal or painted?
              • 43279
              Patrick------
              The bolts which attach the alternator mounting bracket have lock washers. No other exhaust manifold bolts use any sort of washers.
              • Steve M.
                • October 22, 2006
                • 88
                Patrick,
                I believe the throttle spring bracket was attached when the engine was painted so it should at a minimum be partially covered with paint.
                  Patrick -
                  Typically, on engines with aluminum intakes, the spring bracket is zinc-plated; on engines with iron intakes, it's painted engine orange, as noted in the JG.
