C1 Tach removal - NCRS Discussion Boards
C1 Tach removal
  • Richard S.
    • July 31, 2006
    • 187
    C1 Tach removal
    I need to remove the tachometer on my 60' for service. Can the pod be removed to expose the tach without removing all of the wiring harness connections to the gages? In other words, I know both panel assy. need to be removed however, can this be done leaving the gages and speedometer in place?
  • Jim L.
    • September 30, 1979
    • 1816
    Re: C1 Tach removal
    Speedometer has to come off the cluster before you can access the tachometer. No other way.
    The least painful way to work on the tach, in my opinion, is to pull the cluster, set it on your bench, and then disassemble it.
    Jim
    • Bruce B.
      • May 31, 1996
      • 2930
      Re: C1 Tach removal
      I agree with Jim L., pull the whole cluster.
      First disconnect the battery.
      I have found that you can release the 2 sets of gauges from the cluster and let them hang if you don't want to remove the wires from them.
      • Richard S.
        • July 31, 2006
        • 187
        Re: C1 Tach removal
        My thought was that it would take less time and trouble to just let the gauges hang. I am not excited about labeling each wire as it is being removed from the back of the instrument panel.
        • Jim L.
          • 1816
          Re: C1 Tach removal
          I understand your concern.
          However, when I R&Red my '60's cluster, I chose not to tag each little wire and it worked out fine. My reasoning was that the place to attach each wire is fairly obvious and, in fact, wire lengths are so critically manufactured that they simply won't reach much other than their intended terminals. IOW, it's really hard to connect something incorrectly.
          Really, pull the cluster. It's easier that way.
          Jim
          • Thomas H.
            • August 31, 2005
            • 1060
            Re: C1 Tach removal
            Use a digital camera to take pictures of where all the wires go. Then pull the entire cluster.
            Tom
            2007 Z06, Lemans Blue
