A/C hose help. - NCRS Discussion Boards
A/C hose help.
  • Jeffrey S.
    • May 31, 1988
    • 1890
    A/C hose help.
    I would like to ask someone who has a '68 A.I.M. to scan in and post the page that shows the hose that goes from the expansion valve to the receiver/dehydrator. In the '69 A.I.M. it is page D3 in the C60 section titled "Air Conditioning-Refrigerant Hoses". Here's my dilemma-on my early '69 (Oct. 68) car this hose has the end fittings clamped on. The A.I.M shows the hose as one piece with crimped on ends. That hose was changed 10-14-68. Since my car was produced October 28, this change probably did not get to the assembly line by that time and probably got the same hose as listed for '68 which I believe had the clamp configuration. I am pretty sure that the hose I have is original to the car. I do have a new replacement hose with crimped on fittings which, for safety and function sake, I will most likely use. Any help is greatly appreciated.
    Jeff
