69 motor rebuild finding a cam - NCRS Discussion Boards
  • Calvin C.
    • May 31, 2002
    • 240
    I am now rebuilding the 350 for my 1969 corvette. It will be a numbers matching car, driver. The original motor was a 350 hp motor, heads and motor are original. I want To put a roller hd cam in the motor and have between 350 - 370 HP. Can you make some suggestions on which cam might work.
    Thank you
    Cal
  • Joe C.
    • August 31, 1999
    • 4598
    Re: 69 motor rebuild finding a cam
    What's the advertised compression ratio: 10.25 or 11.0?
    You realize that this change requires screw in rocker studs with guide plates, and very likely enlarging the spring pockets.
    • Calvin C.
      • May 31, 2002
      • 240
      I will be built to 10.1 - 10.2
      • Mike F.
        • April 25, 2011
        • 668
        These links may help. I believe the original iron intake manifold will limit you closer to the 350hp(gross) mark.
        https://www.forums.ncrs.org/showthre...-L46-Dyno-Runs
        https://www.forums.ncrs.org/showthread.php?97746-L-46-Dyno-Runs-Part-2
        https://www.forums.ncrs.org/showthre...no-Runs-Part-3
        https://www.forums.ncrs.org/showthre...no-Runs-part-4
        • Calvin C.
          • May 31, 2002
          • 240
          From the Dyno's listed 370hp with 10.1 compression and stock heads and manifolds isn't happening. Ultimately I want good power, stock sound, and drivability. I thought a roller set-up may get me a little more cam and not sound too wild. I couldn't find a roller set-up in those dynos?
          thanks
          cal
          • Gene M.
            • April 1, 1985
            • 4232
            A roller cam in the old unmodified engine is a waste. As Joe says a roller cam alone is not realistic.
            Just clean up the heads and flow them out will give the best return on HP.
            • Calvin C.
              • May 31, 2002
              • 240
              I can see your point, a roller set-up with no power gains in itself is not a good value, however it may not be a waist, which is why I was asking to see if anyone has tried it. I have had better luck with slightly modified motors running a roller set-up, never a flat cam issue for instance, as well as better numbers. But not big gains just by changing to a roller. Sounds like it's not dollar wise though.thankscal
                • 15696
                How much time will it spend above 5000 revs?
                Is power at 2000 - 3000 revs important to you? How about fuel consumption? How about the idle behavior - OE - or typical aftermarket hot rod cam.
                The best thing you can do to a L-46 is massage the heads, use all OE equivalent replacement parts including the cam, and optimize the spark advance map. Limit compression ratio to 10.5 max, and this should be attainable with the OE replacement pistons.
                There are many threads on restoring OE engines for "more power" and revs without screwing up the idle behavior and killing the low end torque and fuel economy, and SHP small blocks yield 270-290 SAE corrected RWHP with the OE manifolds, which is 350-370 SAE gross on a lab dyno. The "secret" to top end power is head flow, not the cam, and substantially more average power (but not top end power), is available across the entire rev range by increasing stroke.
                Engines are not one-dimensional as in maximum power at the top end of the rev range. For a road engine, broad torque bandwidth is what makes the car responsive and quick.
                One issue with '69s is the 2" exhaust system; 2.5" pipes are probably worth 10 RWHP on the top end.
                • Calvin C.
                  • May 31, 2002
                  • 240
                  All good advice
                  thanks
                  cal
