Tilt Wheel and power steering on a 66? - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2589
    I have found a 66 that I am interested in. I have not been to look at the car, but may be going next week. Looks very nice in pictures, of course they all look nice in pictures. A couple of things I need some advice on. It has power steering, but I think this may be an add on. Its not a deal breaker for me, but is there an easy way to tell if it is factory power steering?
    Also, it has a tilt wheel. I assume this has to be some aftermarket product. From the few pictures I have, the steering column pretty much look like a stock one, but there is an extra lever just behind the turn signal lever. I found a company Flaming River that sells tilt columns. Not sure if that is the only one, but is anyone familiar with this addition?
    Don Harris
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
    • 43281
    Re: Tilt Wheel and power steering on a 66?
    Don Harris
    Don------
    If the power steering is a factory set-up, as most installed on Corvettes are, it's pretty hard to tell an original installation from a retrofitted installation. Even if incorrect components are observed, you still don't know if that indicates a retrofit since an original system could have been serviced with incorrect components. The only real way to tell is original documentation.
    I am not familiar with retrofit tilt columns. However and of course, we know that no 1966 was ever originally fitted with a tilt column. The first year for tilt column in a Corvette was 1969. I don't think a 1969 column can be retrofitted to a 1966 and, even if it could, it would not look at all like a 1966 column. So, whatever column is installed in this car, it has to be an aftermarket, retrofit type. Personally, I wouldn't want that sort of thing.
    • Russ S.
      • April 30, 1982
      • 2163
      It is most likely a flaming river column or an ididit.
      • Donald H.
        • November 2, 2009
        • 2589
        Thanks Joe and Russ.
        Don't think I will be going after this one. Some other things with the car give me concern, especially at the price they are asking.
        Don
        Don Harris
