1962 Assembly Instruction Manual - NCRS Discussion Boards
  • John M.
    • November 1, 1988
    • 170
    Does anyone have a1962 Corvette Assembly Instruction Manual (AIM) from EARLY production prior to March 1962?
    The page I am interested in is numbered B207, section 313, sheet 3.00 in my AIM, and addresses components of the Powerglide Transmission. This page was revised twice; 7-3-61 & 3-7-62. I would like to get a copy of this page at least pre-revision 3-7-62 for a project I am working on. If anyone can help, do it here, send a PM, or contact me at jgmattson@hotmail.com.
    • 15603
    • John M.
      • November 1, 1988
      • 170
      Re: 1962 Assembly Instruction Manual
      Terry,
      Wouldn't the Section Number & Sheet Number of the AIM remain the same as original regardless of how any vendor numbered the pages in any reprint?
      Save the Wave . JGM
        • 15603
        Originally posted by John Mattson (13840)
        Terry,
        Save the Wave . JGM
        John,
        I was going to comment on that, but I am unfamiliar with that numbering system. I am more familiar with the C2/C3 page numbering system that uses a UPC code and a sheet number. If the section number and sheet number are the equivalent of the UPC code and sheet number then you are correct.
        • Christopher R.
          • March 31, 1975
          • 1599
          My copy of the '62 AIM is from Mid America and is dated 1977. I remember I got it pretty early. My copy has the same 3-7-62 Revision level.
          • Loren L.
            • April 30, 1976
            • 4104
            Check the Equivalent sheet from the 1961 AIM for content.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11324
              Loren has a good idea, and because of that, he made me look in my '61 AIM.....
              But........
              313 - 3.00 is safety switch and control lever bracket for '62, but it's 313 - 4.00 in the '61 AIM
              And........ lots of differences in the designs. Different safety switch, and didn't they reverse the direction of the shift lever or something like that? I see the indicator plates are different, and lever locations are reversed.
              John, What exactly do you need information for?
              Rich
              • Mike E.
                • February 28, 1975
                • 5139
                Major changes between 61 and 62 power glides. Cast iron to aluminum. Shifter bracket vs. shifter bolts to side of tail shaft. Etc, etc.
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11324
                  Mike, Did the shift pattern change 180*?
                  • John M.
                    • November 1, 1988
                    • 170
                    Rich,
                    The Aim page you have pictured is the cast iron powerglide, completely different from the aluminum case 2-speed powerglide for the 1962 model.
                    The reason I am looking for this information is to identify the neutral safety switch control rod prior to its revision, and that the revision control rod never made it to production. I have a lot of this info right now and thought if a pre-revision page exists somewhere and is available I would like to see it. This is information that will probably be Restorer bound someday.
                    Save the Wave ......... JGM
