Re: C1 fuel problem
Joe,The rubber hose from the main fuel line to the engine fuel pump. Go to local auto store and ask for a hose that's good enough for ethanol.
Here's a story about rubber hoses and ethanol. In short order the cheap rubber hoses start to separate. Then they come apart and swell up letting little or no fuel go thru. And when they do the fuel is crap.
Have proof.
Buy accelerator pumps that are for alky aka ethanol. Now I understand the old leather acceleraor pumps are a lot better than the rubber ones in the rebuild kits.
There are companies that sell carb kits for ethanol.
Also how old is your fuel. Drain it and put some fresh fuel in the tank. Ethanol separates you know.
Sticking needle and seat can cause this problem too. Old ethanol will just about weld those two parts together. After you get the car started go buy some good fuel injection cleaner and use it according to the instructions. Replace the filter in the fuel bowl also. NAPA has them or our Corvette catalogs have them also.
You cannot let a car sit for 6 months. Only if you are in Canada. Oops. Not supposed to take shots here.
Go on line and type: Pure-Gas.Org. Click on your state and see a list of gas stations that have pure gas. PA has around 38 of them (old info). But most of them are low octane.
Switch to racing fuel or 100LL aviation fuel.
Take the gas cap off and smell the fuel. If the odor knocks your socks off you solved the issue. Good luck. JD
P.S. EThanol is klling some of the fuel pumps also.
Have proof.
......Rich
