Auto trans cooling line pressure - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    Can someone give me an idea of the pressure that occurs in transmission cooling lines that run to and from a trans cooler.
    Info on both Powerglides and the Turbo 350 trans would be appreciated.
    • 43246
    Re: Auto trans cooling line pressure
    Bruce------
    Powerglides don't use external cooling. I don't know what the pressure is for a Turbo 350. However, Turbo 400 pressure runs in the range of 25-50 PSI. I would expect the Turbo 350 to be approximately the same.
    • Bruce B.
      • May 31, 1996
      • 2930
      Joe,
      Thanks for the info.
      I thought the 63 and up aluminum PGs had external cooling, but I have been wrong before.
        • 15615
        Bruce------
        I am pretty sure some C2s use cooling with the Powerglide. I remember a story in The Restorer about restoring one.
        • Mike M.
          • May 31, 1974
          • 8400
          terry and bruce are correct. 63's corvettes with power glide definitely had a cooler as did our 67 390 hp power glide. i believe all c-2s with power glides were externally cooled. mike
          y
          • Michael H.
            • January 29, 2008
            • 7477
            I think all 63-67's with Powerglide (with the exception of early 63) had the remote cooler.
            • Jim T.
              • March 1, 1993
              • 5351
              My 1964 was a 4-speed, but my 1964 service manual has a picture of the transmission cooler for the power glide on page 7-19 mounted in front of the radiator and slanted towards the front.
              • Michael H.
                • January 29, 2008
                • 7477
                There should be a drawing of the cooler in the Powerglide section of the 63-67 AIM's.
                  • 43246
                  Joe,
                  Bruce------
                  Yes, I was thinking of the pre-1962 cast iron Powerglides. The later aluminum Powerglides did have external cooling. I don't know what the pressure was, though. I would not expect it would have been very high.
                    The 1967 Chassis Service Manual has a section on Powerglide test pressures (page 7-34), and they vary from 50 to 125 psi. Similar test pressure charts in the 1961 Passenger Car Shop Manual (page 13-37) for the old cast iron Powerglide range from 40 to 275 psi.
                    • Larry M.
                      • January 1, 1992
                      • 2700
                      Bruce------
                      Agree with Joe. Info from other car forums indicate auto trans cooling line pressures in the range of 30-50 psig. Goodyear transmission hose is rated at 250 psig working pressure, so it is plenty good. I have also run replacement lines using copper tubing and stainless steel tubing. Copper is obviously much easier to fabricate, but could be a problem for long term road use.
                      Larry
