1966 427 425 Fan Shroud Flange - NCRS Discussion Boards
  • Barry J.
    • May 28, 2009
    • 61
    I have missed placed the broken driver side flange that bolts the shroud to the car. Anyone have any idea if this flange can be purchased? I would really like to keep the original shroud in the car and just class in a new flange.
    Any thoughts, I know these flanges often break off?
    • 43246
    Re: 1966 427 425 Fan Shroud Flange
    Barry------
    If you're referring to the flange which is an integral part of the shroud and which bolts to the radiator support, I know of no source for that piece. I would guess that your best bet would be to obtain a used shroud generally in bad shape but with the part you need in good shape. Remove the part you need.
    • Barry J.
      • May 28, 2009
      • 61
      That is correct the flange that bolts the driver side. I noticed that several suppliers (corvette America, Volunteer Vette, Eklers, etc have the shroud new and a note that is a three piece unit but do they sell those three individually?
      Any idea who would have a driver side flange with the bolt holes still intact?
      • Mike M.
        • May 31, 1974
        • 8400
        try sermersheimers in indiana. mike
        • Marco H.
          • March 1, 2002
          • 218
          Barry,
          Sermersheim (Lee Bump Fiberglass) should sell shroud sections. A used shroud would be a better choice, since the new parts usually have a gel coat.
